S video probs on DAV s-500
Discussion in 'Blu-ray & DVD Players & Recorders' started by s9s, Apr 9, 2002.
  1. s9s
    s9s
    Just watched Final Fantasy on mates DAVs-500, stopped the flm and then some srolling appeared on screen from left to right, reconnected using red, white, yellow leads, all ok. Reconnectd back from s-video out to scart adapter to tele and scrolling reappeared.
    I dont have much idea about this system and my friend is not really a technophile, so any clues/ solutions would be grateful.
  2. John Jennings
    John Jennings
    Aug 7, 2001
    282
    Uppsala, Sweden
    +5
    What do you mean by "some scrolling appeared"?
  3. s9s
    s9s
    Basically, i a light band from top to bottom about 3"thick scrolls from left to right as if some sort if bad reception signal. As this set up was working perfectly before im thiking that maybe the cable is faulty?
    FYI my friend has 32" sony fq (no probs with the set).
  4. John Jennings
    John Jennings
    Aug 7, 2001
    282
    Uppsala, Sweden
    +5
  5. s9s
    s9s
    no probs with the set JJ, and the scrolloing only appears when s-video is connected.
