S-video problem with Panasonic TX-W36D3DP tv
Discussion in 'General TV Discussions Forum' started by pcavelle, Jun 26, 2001.
Tags:
  1. pcavelle
    pcavelle
    Jan 23, 2001
    985
    London
    +16
    S Video (from my DVD player) only appears to work through the s-video socket on the front of the TV (messy) & not from the s-video enabled scart socket - av2. If I use this socket, the an s-video-scart adaptor I get a black & white picture.
    Could this be a configuration problem with the rear scart, or just a fault?
    All suggestions welcomed. Thanks - Paul
  2. Aidan
    Aidan
    To get a colour picture you have to set AV2 to AV2s, on my Panny PK1 this is achieved by pressing the AV2 button twice but on my old Sony I had to go into the setup menu and specify that the input was S-Video through that socket. Not sure which method you will have to use but one should work for you.
    Aidan
  3. pcavelle
    pcavelle
    Jan 23, 2001
    985
    London
    +16
    Cheers Aidan - that sounds like a top option to me; at the moment I'm using a Pronto & didn't even realise there was a av2-s setting.
    Thanks - Paul
