S-Video PAL graphics cards - can you recommend one
Discussion in 'Microsoft Windows' started by Powys, Aug 27, 2006.
  1. Powys
    Powys
    I would like to replace the Pace Twin PVR with MCE system, but the graphic cards I have tried do not match the quality of the Pace S-Video output. The difference is most easily seen in the sharpness of the text.
    I am using the same S-Video cable for the comparison, so it is not a cable issue. The display on a PC screen is near perfect, so it is not the tuner.
    I have tried both Ati Radeon and Nvidia cards. The Radeon is noticeable better than the Nvidia.
    The TV is Panasonic 26in LCD TX-26LXD1
    Tuner is Cinergy 2400iDT
    OS - MCE with Rollup2
    CPU - Core2Duo E6300
    Graphics cards tried:
    GeForce 7300 GS and Forceware v91.31
    ATI Radeon RX600 and Catalyst v6.2
    S-Video format: i-pal
    Any suggestions for a graphics card with high quality i-Pal S-Video?
  2. craigizmo2k2
    craigizmo2k2
    Jun 13, 2005
    1,867
    Boston, Lincolnshire
    +166
    If you're going into an LCD screen, why not use the VGA input (assuming it has one)
    You will find it extremelly difficult to get readable text if using a high PC res over s-video i'm afraid, but as you noticed - ATi Radeon TV outputs are very good.
  3. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    No s-video out on a graphics card will match the picture quality of even the cheapest Set Top Box. With some ATI Radeon cards you can get a VGA->RGB SCART cable made up. Otherwise just use the DVI or VGA out.
