S video out
Discussion in 'Digital TV & Video Players & Recorders' started by paiger, Feb 26, 2002.
Tags:
  1. paiger
    paiger
    May be a stupad question but I'm thinking of getting a Sharp 2000 SVHS VCR and hooking to my TV's AV2 (Svid) scart socket with an Svideo to Scart lead. Will this play standard tapes OK or can I only send Svhs signals from the svideo out? For example, if I record a program from my Sky box (connected to scart on VCR) in composite video, can I play that through the Svideo out to my TV. I think it should be OK but I always seem to end up with black and white when mucking about with the settings on my DVD.
    S
  2. Beamer
    Beamer
    Feb 20, 2002
    297
    Bucks
    +5
    Hi Paiger
    You should be able to operate this way without problems but do not expect to get picture improvement without recording from an S-VHS source.
    Why don't you get an RGB converter for your Sky box and feed your tape with S-VHS!
  3. bob007
    bob007
    I have a JVC S-VHS connected to AV2/S-VIDEO, plays VHS tapes ok. You get a slightly better picture watching VHS tapes through S-VIDEO than you would through composite.
    You record SKY in composite, recorded on to a S-VHS tape (approx 400 lines, VHS are about 240) then output via S-VIDEO.
    Digital recordings are better with S-VHS tapes.
    The reason for this could be, if youv'e got the DVD connected to AV1 RGB and switch the DVD player to S-VIDEO it will only play in black and white.
    AV1 is 9/10 RGB and Composite only, AV2/AV3 etc are composite and S-VIDEO, then some TV's require you to go into the menu and configure it to S-VIDEO, this does vary on different sets, worth checking.
  4. paiger
    paiger
    OK, thanks, got it all sorted now. I would like to use an RGB Svid converter but my Sky box only has one RGB out and this goes to the TV, the other is composite. THe other problem is that the Svid in on the Sharp is on the front and I don't want leads hanging out everywhere so I'll just record in comp I spose.
    S
  5. Kevo
    Kevo
    Aug 23, 2001
    5,412
    Manchester
    +151
    DO consider the converter.
    I recently purchased one and it makes a BIG difference to the SVHS recorded quality.
    I have leads 'hanging' out of the front of my VCR too, although I could use AV2 on the rear of the VCR, as this can be configured to input S-Video. I would need an S-Video mini-din to SCART lead for this (Converter to VCR), which I'll get round to buying in the future.
    Don't know if you can configure the SCARTs on the Sharp model but you can on most of the JVCs, which btw, give an excellent SVHS picture. I have the HRS-8850 model.
  6. vgmf
    vgmf
    Oct 22, 2001
    Try these guys >> http://www.rgbtosvideo.com/
    I have one of their RGB to Svideo convertors and it is brilliant. they also do an active video buffer which will take a single RGB scart in and then produce two perfrct RGB scarts out. You could then attach a convertor to each ,and then run to the TV and one to the video.
  7. paiger
    paiger
    In a minute my neighbours are going to ask why their lights keep dimming when I watch TV. Thanks for your input guys, I'm coming up with a solution using the converters and will look at JVC vids. I wanted the Sharp because it's full size, cheap and matches my gear in colour. Supposed to be no mean performer too.
    S
