s video or scart
Discussion in 'Plasma TVs' started by oscarmadfish, Dec 4, 2004.
  1. oscarmadfish
    oscarmadfish
    which is the best for dvd and plasma
    top range scart or top range s video lead ?
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,549
    Galactica C.I.C.
    +199
    well, you can also have svideo through a scart lead , as well as composite and RGB. It all depeneds on how it is connected. If you dvd player has componenet outputs and so does the plasma, then that would be the best way to go.
    Generally speaking RGB is supposede to be the better than svideo, however some people on the forum will say that svideo is better
    Best to worse is as follows. Component :smashin: ..........RGB. :thumbsup: ........svideo :) .......composite :nono: ..........rf coaxil lead :thumbsdow
