S-video or rgb scart
Discussion in 'Cables & Switches' started by Mad Mikeyboy, Sep 2, 2004.
  1. Mad Mikeyboy
    Mad Mikeyboy
    Jun 23, 2004
    356
    Renfrew
    +12
    Easy one for those in the know. will I get better PQ with my DVD through S-vid or through RGB scart?
  2. WYNIR0
    WYNIR0
    Jul 16, 2004
    190
    London
    +12
    General concensus is RGB SCART is preferable to S video.
  3. Mad Mikeyboy
    Mad Mikeyboy
    Jun 23, 2004
    356
    Renfrew
    +12
    Damn it!!! Just spent £20 on new S-vid cable :mad:
  4. WYNIR0
    WYNIR0
    Jul 16, 2004
    190
    London
    +12
    Why not borrow a fully wired SCART and compare the 2?.
    If the SVID looks ok to you, why change?
  5. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,906
    You should ask the question before you buy and not afterwards :D
  6. Mad Mikeyboy
    Mad Mikeyboy
    Jun 23, 2004
    356
    Renfrew
    +12
    It appears I gave you all a bum steer anyway. What I actually have is a home cinema system which was just connected via the yellow video plug into a scart.........which of these is best then??
  7. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,906
    The yellow video plug is composite which is generally acknowledged to be the poorest quality.
    If you have a scart output on your HC system it may well have RGB in which case you should use that. If it doesn't have a scart but it does have a s-video socket - use that instead. Either should show a considerable improvement over the yellow composite connection
  8. Mad Mikeyboy
    Mad Mikeyboy
    Jun 23, 2004
    356
    Renfrew
    +12
    Excellent!!
    £20 well spent then...although hooked up the s-vid and did'nt see a great deal of improvement.
    There is no scart connection just the composite and s-vid.
    Still looks brill anyway but you know how it is. If you can make it even better you'll try anything.
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,032
    The Borders
    +3,164
    OK
    Try this - with one foot on the ground hold a 6" length of OFC Cable exactly 24" above your left eye. Now tilt your head to the right and then ... :laugh:
    Best regards
    Joe
  10. FoxyMulder
    FoxyMulder
    If your DVD player is a Toshiba its worth noting that you might get superior picture quality using s-video and not RGB although both will give very good results the s-video with Toshiba DVD players is sometimes superior although the colour balance is slightly worse i would say S-video can give sharper more detailed pictures with Toshiba.
