s video or component?,no groans please!
Discussion in 'Cables & Switches' started by reevesy, Apr 29, 2005.
  1. reevesy
    reevesy
    Feb 20, 2005
    5,694
    +1,703
    i know this is a bit of a no brainer but i'm thinking of connecting a digi box via a rgb to component converter to my projector .i've got both component and s video cables installed but thought about using a scart to s video / L and R audio cable via my amp as a temp. measure until funds become available.question is, is the quality going to be massively improved using the converter or will an s video suffice as a cheaper option? if it makes any differance i'm probably only going to use it for box office movies and music channels.cheers in advance
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,909
    The Borders
    +3,126
    reevesy
    The key to your 'low cost' plan is the ability of your Source to actually Output S-Video - most SCART equipped Digibox units only Output RGB or Composite not S-Video.
    A SCART to S-Video cable is wired to work with a Source that actually Outputs S-Video on the SCART socket - the cable cant 'convert' RGB or Composite to S-Video; if there's no S-Video 'Option' on the Source you wont get an image using a SCART to S-Video cable.
    Best regards
    Joe
  3. reevesy
    reevesy
    Feb 20, 2005
    5,694
    +1,703
    looks like the component option sooner rather than later.
    chhers
