s video long runs
Discussion in 'Cables & Switches' started by krusty, Nov 28, 2004.
  1. krusty
    krusty
    at present im using a 10 metre s video which i alternate between a tv , and then [ because of its length] use for a projector. if i use a much shorter length[ say 1 metre] for the tv useage will there be much difference in picture quality?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    depends on the quality of the long cable you are using
