s-video in?
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by panadol, Feb 6, 2003.
  1. panadol
    panadol
    Dear all,
    I am using canon ZR65mc,
    i am doubt that whether this camcorder has S-video in. So i can import video tape from recorder onto DV tape through S-video port..
    anybody know that?
    thanks
  2. Brian110507
    Brian110507
    Dont know your particular camera (is this an American spec camera) but normally if you want to import video onto a DV tape you need to use the 'firewire' (IEE1394) port but you may need to enable DV-in on your camcorder by means of a 'widget' or a PC software programme.
    If you could modify your profile to put something useful in the 'Location' box it would help as it's not a lot of good me telling you to pop into Argos to solve your problem if your in the USA.
