S video in black and white
Discussion in 'General TV Discussions Forum' started by Taz, Mar 18, 2002.
  1. Taz
    Taz
    Hi all,
    I am trying to connect my Sky+ with Svideo to my Philips 32" TV.
    The connections are...
    Sky to Amp (A2) S video to S video
    Amp to TV S video to scart lead
    the picture quality is much better, but its black and white!
    makes no difference on all 3 scart inputs on the tv
    Whats going wrong here:confused:
    Taz.:cool:
  2. encaser
    encaser
    Mar 15, 2001
    2,383
    116
    Suffolk/Essex
    +535
    checked your tv AV menu/input for s-video recognition?
  3. Taz
    Taz
    Yep... checked everything I can think of!
    Taz.:cool:
  4. encaser
    encaser
    Mar 15, 2001
    2,383
    116
    Suffolk/Essex
    +535
    tried taking it from the sky+ box direct to tv to see if amp setting needs applying and not tv. Does sky+ box need setting menu wise for s-vid. How about an Asprin, I can recomend some of those?!
  5. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    Portsmouth / Middle East
    +77
    Bad news chum,
    The two systems are totally incompatible. Different languages like French and English. If you wanna pursue this you need a s/video to scart/rgb-scart converter. I would just connect this in a different scart port on your set.
    Failing that I think Lectropaks sell an RGB scart switcher box, thats if you've run out of RGB inputs, which is what I'm guessing!!?
  6. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    The SCART connector on Philips TV's that supports S-video is EXT2, the other(s) do not.
    I assume you're using an S-video to SCART converter block. Have you tried it on other sets to see if it works on them? Some converter blocks are made for input to S-VHS VCR's and send color through different pins than normal.
  7. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Taz is using an s-video to SCART lead that I used to use from my Denon receiver to my Panasonic TV. Works fine.
    Snowman: SCARTs can accpet RGB, CVBS, s-video or component (Y-Cb-Cr), so there is no problem providng you select the right SCART input.
  8. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    18,515
    Inbetween Upgrades !
    +6,838
    Taz,
    I know this may sound really simple but, when you select your scart input with your AV button, try pressing it again. On my TV this selects S-Video. Worth a try hey ?
    Kev
  9. paiger
    paiger
    I believe said leads are directional. Dunno if this would make any difference but just a thought. I guess you are using something like the IXOS Svid+2 RCA to Scart. I think they do one in reverse too.
  10. Doubledoom
    Doubledoom
    Why not use the scart connection to the tv and get RGB instead of s-video, rather than routing it via the amp?
  11. bob007
    bob007
    Hi Taz,
    I go with DD on this, scart to TV and select RGB, but if your preference is S-Video then mozzer may have your answer, my son has a 24 Phillip W/S in his room and can remember going through the AV connections manually once and saw this come up on the screen when i pressed the button twice, worth a try.
    BTW chicken come out spot on.......;)
    Have you got a good receipe for bacon rolly polly..:D
  12. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    +77
    If they are fully wired. YES. :eek:
  13. Taz
    Taz
    YAHOO! I have done it!:D
    just needed a different s video lead from Sky to amp and scart in AV2.:D
    Thanks to ReTrO, Jeff, Frosty.. and all of you that replied... I got a nice picture now;)
    Taz.:cool:
