s-video - how useful is it?
Discussion in 'Blu-ray & DVD Players & Recorders' started by derb, Apr 26, 2003.
  1. derb
    derb
    My panny is connected to my VHS VCR via a video and two audio leads (in) plugged into a scart on my VCR (out). Is it worth my adding an s-video cable to the existing combination? Would it make recordings made from my video any better?
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    I'm sorry but I don't quite understand your original post (it's been a long day so it's probably me) but what is 'your Panny' - a SVHS, a digibox, a E30/50/HS2?
    Although picture quality is subjective I don't think there are many people who will argue that S-Video is 10 times better than composite (which is the normal method of connection). However you will need to check your VCR can output S-Video. If not then composite is the best you will get from it as no VCRs can do RGB or component out.
  3. derb
    derb
    Sorry - it's an e50. My VCR doesn't seem to have a dedicated s-video connection - there's just a plug for one in the phono-scart box I have. If what you say is the case, then why did they include an S-video cable connection at all? Is it only for devices that don't have a composite connection?
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    Some devices can output S-Video through a Scart socket, e.g. an SVHS VCR which is why S-Video is included in such a device.
    If your archiving video to DVD then your probably best using a screened scart lead rather than individual leads as this will give the best picture. There's no need to spend a fortune on leads from a VCR (as the picture will never be THAT good) but you will get a better picture if you use a decent Scart.
    Run the Scart from your output Scart on the VCR to AV2 on the E50.
  5. derb
    derb
    Alas AV2 goes to my digital cable box. Panasonic suggests I plug my VCR into AV4 (which is phonos for audio in and video in plus an svideo jack). AV1 is an output SCART I believe so I can't use that. Does this mean I am already doing the best I can do then?
  6. bobbles
    bobbles
    Another option is to get a scart switchbox, you can only record one thing at once.
  7. derb
    derb
    Oho - good thought. But I don't fancy having to reach around behind my machine each time I want to switch from one to the other and I am sure I would manage to mix them up. I think I will live with the system the way it is. Thanks for the input, though (did I mention this board is absolutely excellent?)
  8. bobbles
    bobbles
    I would recommend the Argos scart switch box less than a tenner and allows RGB
    It is the one without! the scart attached
  9. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,875
    3
    48
    +78
    Yes,probably.
    There's not much in it between S-Video and Composite really.
    DVD-RAM/-R is better than VHS/S-VHS anyway.
  10. bobbles
    bobbles
    I think there is a significant difference in quality from s-video to composite
  11. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    I agree - picture quality is always subjective but I've found it to be much nicer. My old E20 only had S-Video or Composite in so I had to record like that from Sky+ - and S-Video was much better. RGB is better still IMHO.
  12. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +93
  13. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,875
    3
    48
    +78
  14. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +93
    Great, thanks for That!!
  15. bobbles
    bobbles
    just to confirm the one I have is the 534/0370
    avoid the other one like the plague as it doesn't allow an RGB signal
    Without a doubt IMO too
  16. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    Derb,
    Are you saying your VCR doesnt actually have an S video out connection?
    If its not an S-VHS vcr then its unlikely to provide an S-video out signal. In which case, no theres no point using the Svideo connection
