S video from scart
Discussion in 'Satellite TV, Sky TV & FreeSat' started by bazg, Jul 26, 2002.
  1. bazg
    bazg
    Is it possible to get a s video output via the scart on a pace digibox, any help would be appreciated.
    Bazg
  2. gbmitie
    gbmitie
    Apr 25, 2001
    1,147
    49
    republic of ireland now
    +65
    No. U need a box that has a dedicated S-Video output. The grundig has one.
    gbmitie
  3. encaser
    encaser
    Mar 15, 2001
    2,390
    116
    Suffolk/Essex
    +540
    If you're on about the free to air Pace box, then yes it is suppose to put out rgb, s-video or composite via its scart.
  4. Squirrel God
    Squirrel God
    Bazg,
    I think you better post exactly which Pace box you're talking about. ;)
    If it's the Pace DTVA, then as Encaser says, it does S-Video, RGB and composite through the scart. You just have to select which you want via the setup menus (hit Menu on the remote to bring up the setup menus). Don't forget to also enable S-Video on whichever TV scart you are using (if your TV requires this, via the TV's menus).
  5. paiger
    paiger
    If it's just RGB you can get one of these www.rgbtosvideo.com which apparently work a treat.
