S-Video connections
Discussion in 'Blu-ray & DVD Players & Recorders' started by dolph, Feb 3, 2003.
  1. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    I have just bought the SONY DAVC770 system, now I'm hooking this up to a Sony TV that has two RGB scarts and an S-VHS scart. The DAV system has either component out or s-video out (no scart) so I've got myself an S-VIDEO to Scart cable.
    Am I best to put this into Scart 3 (S-VHS) and if I then get myself an S-VHS VCR what do I do?
    Can and S-video cable carry an RGB signal?
    Andrew
  2. Silent Fly
    Silent Fly
    Scart 3, should be ok but you can probably use Scart 1 or Scart 2 as well.
    If you buy a s-vhs vcr you can connect it to the telly using a cable like to one you just bought.
    Scart 1 (RGB): sky or digital set top box
    Scart 2 (s-video): DAVC770
    Scart 3 (s-video): S-VHS VCR
    No.
    As a simple rule you can say that:
    Composite: RCA cable
    S-VIDEO: s-video cable
    RGB: SCART
    However, SCART cables be used to send/receive composite, s-video or RGB signals.
    Things are sligthy more complicated but for the devices you mentioned this should be enough.
  3. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    Does this mean I can set the second RGB scart to receive an S-video signal?
  4. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    Can someone help on this - can an RGB scart properly accept an s-video signal. Does the sony allow you to change what the scart is going to accept?
  5. Silent Fly
    Silent Fly
    The 1st, 2nd and 3rd SCART should all allow s-video signals.
    I would suggest you read the user manual of the TV set. It should explain how to set up the SCART ports.
    Probably you do not need to do anything but I think is worth to verify.
  6. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    If one of the SCART's is labelled S-VHS then that is most likely the only SCART that supports S-video.
    S-video was introduced to the consumer market when S-VHS and Hi8 were released in the late 80's. In the old VHS system, the resolution in the recording is already so poor that it can be fit into a regular composite video signal without much loss, and cannot gain much when recording from a better connection.
    S-VHS and Hi8 had enough resolution that they could gain from better connections than composite video, so S-video conections were added. Like composite video they contain a black and white picture (luminance) and a color signal (chrominance) carried on a subcarrier, but they are led through separate wires in the cable. This way they do not interfere and limit each others resolution like they do in a composite signal, where they are added together.
    At first, S-video inputs and outputs were found only on said S-VHS and Hi8 equipment and this made people see them as synonymous. Therefore, many companies started calling S-video connectors S-VHS connectors, which is wrong but simple to market. Today those connectors are getting more uncommon as S-video can also be transferred over the pins in a SCART connector. In good (or bad) tradition, SCART connectors that can handle S-video are often labelled S-VHS by manufacturers.
    A SCART connector can be made accept any or all of the signal forms (composite, S-video, RGB and even "component") but this is rarely done to all SCART's for reasons of cost. Usually only one SCART accepts S-video and one or two accept RGB, but this may differ on some sets. Reasonably speaking, all SCART connectors should accept composite video.
    I have a little more info stored at:
    http://members.chello.se/zacabeb/whims/tvtech/videosignals/index.html
  7. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    OK, as I can't use both a S-VHS video and my DAV through S-video output, can you get a component to scart cable - this way I could use the component RGB output on the DAV to and RGB scart input on the TV and save the S-VHS scart for my VCR.
    If you can has anyone give me any suggestions?
  8. Silent Fly
    Silent Fly
    andrewdolphin,
    you cannot connect directly the component outputs of the DAV to the SCART input of the TV.
    A cable alone would not be enough. You would need a converter
    components->RGB or
    components->S-VIDEO or
    components->composite
  9. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    If you have to make a choice in what device to connect through S-video, I think you should prioritize the AV center and connect S-VHS through one of the other SCART's. Then you will only get composite video for S-VHS, but DVD deserves S-video much more.
