S-VIDEO Connection on Sanyo Z2.
Scotty12
OK, Here goes. Now that I have decided on getting a Z2 for my first projector, I would like to ask for some information on connectivity.
My DVD Player has only has RGB SCART & NTL Box is also RGB SCART out.
To connect up to the PJ, I am thinking of :
DVD : RGB SCART -> S-VIDEO on amp
NTL Box : RGB SCART -> S-VIDEO on amp
AMP : S-VIDEO -> S-VIDEO on PJ
I don't know if this is the best way to connect, I am not a very good connection's guy!!
Is this a viable way to connect, or is there better?.
K
krlock
hmmm... im also not an expert, but if you are gonna get the z2, you should treat it to a half decent dvd player.... with at least a dedicated s-video socket, and preferably component video, which i assume your amp could take??
remember, that you wont be looking at a 21inch crt anymore......
good luck, im sure whatever you do, you will enjoy your z2!!!!!!!!!!!!!
well done for taking the plunge!!
krlock
KraGorn
I agree with krlock, you'd be far better off investing something like £150 on a decent but cheap DVD player, something like a Sony 730, which can feed component into the Z2 .. or a cheap DVI-equipped one like a Samsung, only trouble with those is that none are distributed in this country AFAIK, you'd need to import.
Using S-Video on the Z2 would be a real waste .. your alternative would be to get an RGB->Component converter but that'll cost a good part of the price of a 730 or similar.
Plug the NTL box and the DVD player into the PJ and use the remote to select source.
G a f f e r
In order of best input to worst it goes something like:
DVI/HDMI (digital), Component (analogue), RGB Scart (analogue), S-Video (analogue), Composite (analogue).
If you go to the high street, you can get a JVC scart lead that ends in component YPbPr phonos (as opposed to the scart-----compsite+audio lead). This lead is around £13 from dixons/Currys.
So I'd suggest:
DVD: RGB SCART-------Component (not vid+aud) on proj
NTL BOX: RGB SCART--S-Video on proj
Amp: shouldn't need to connect this to your projector at all.
PS yes, you read that right, scart to component not the usual scart to video and audio. I'm pretty sure cos I checked the box twice. (JVC VX-217 scart rgb to 3 phono lead YBR)
K
Kramer
If the DVD player outputs RGB via scart, a cable (such as that from JVC) will not give component out. If the Z2 accepts "scart" RGB via its component connections, then it's basically a different way of getting RBG into the PJ.
A few DVD players can output component via scart but they are the execption.
As KraGorn says, you'll need an RGB/component convertor but I too would recommend a new DVD player (component or DVI).
:smoke:
Podcast: LG C1 OLED First Thoughts + JBL Synthesis SDR-35 Review, TV Show & Disc Reviews & more
