s - video connection (digibox - tv)
Discussion in 'General TV Discussions Forum' started by captaindobie, May 14, 2002.
  1. captaindobie
    captaindobie
    Apr 17, 2002
    592
    Scotland
    +21
    Hello.
    Small query. I have my Grundig digibox connected via s - video to a Sony KV28FX65. While watching sky digital broadcasts i sometimes notice a vertical white line on screen about 2/3 along (left to right). The line is not always visible. but causes minor irritation especially on dark scenes where it can spoil the overall picture. Would simply purchasing a higher quality cable eliminate this problem ? Or is there something else i should be looking for. The cable i currently use is a rather inexpensive number for about £10. Any help greatly appreciated.
    :confused: :confused: :confused:
  2. encaser
    encaser
    Mar 15, 2001
    3,641
    Suffolk/Essex
    +1,251
    Why not use an RGB signal from the box via scart as this should give best results?
    Some widescreen tvs are noted for having a vertical or horizontal line (maybe both - Panasonic pg50, huk tu) - try search on here for posts on your set model.
  3. captaindobie
    captaindobie
    Apr 17, 2002
    592
    Scotland
    +21
    Ah, well you see. I am one of these weird people who thinks the s - video output from the grundig looks better than rgb !
    I currently use the tv's only RGB scart input to connect my sony dvd player (which i happen to think looks better than the s- video connection). I appreciate the help though. Thanks.:)
  4. Doubledoom
    Doubledoom
    Most of the Sony DVD players have 2 scarts and will pass the RGB signal from the digibox. Just in case you ever change your mind and want RGB for both.
