S-Video Cables
Discussion in 'Cables & Switches' started by spannerman, Aug 21, 2004.
  1. spannerman
    spannerman
    Jul 21, 2004
    16
    LUTON, Beds. UK
    Hi all, 1. Are s-video cables usually male to male? 2. If I want to connect s-video 'out' to the s-video 'in' on another component, is this the configuration of cable that I require? The problem is that I can connect my DVD recorder to my Thomson DTH 7000e and record to the Thomson hard drive, but I can't seem to get a link from the Thomson hard drive to record to my DVD recorder. The reason being is that certain recordings I wish to keep on a DVD-R disc. Any other suggestions?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    S-video are normally Male to Male have seen a few extesions male to female but quite rare.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,425
    The Borders
    +3,231
    spannerman
    I take it you understand you need 2 x S-Video cables - assuming your DVD Recorder has an S-Video Input for the return signal from the Thomson DVD/HDR.
    The DTH 700E has separate S-Video In and S-Video out and your DVD Recorder will require the same if you want to Record onto DVD from the HDR.
    Both cables will be Male to Male S-Video.
    Best regards
    Joe
  4. spannerman
    spannerman
    Jul 21, 2004
    16
    LUTON, Beds. UK
    Joe, I was only going to connect s-video out on the Thomson to the s-video in on my dvd recorder so that I can record from the Thomson, transfer is OK in the other direction
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,425
    The Borders
    +3,231
    spannerman
    So assuming you have an S-Video cable in place from the S-Video Out on the Thompson to the S-Video In on the DVD Recorder have you ensured your units are set to send and receive S-Video on the relevant Inputs and Outputs; I know with my Pioneer DVD-R you have to tell it what to look for and what to send.
    Best regards
    Joe
