S-Video Cable
can any one recommend a good s-video cable for use at 10m, and where to best to buy it from, im gonna need 2 so cant really stretch to mark grants
cheers lee :thumbsup:
L
loadsofleads
Hi lee, what kind of budget are you on. Supra's 'off the shelve' S-video cables only go to 2 meters ! A custom one at 10 meters could be built for you of course.
around 30-40 per cable, pref more towards 30 as i need 2
cheers lee
SimonO
Mark Grant
L
loadsofleads
ohhhh :oops: I think supra charge about £10 a meter for their AV2 cable which they use with S-video connections. Slightly off your budget, you could have a dig around the forum sponsors, alternatively try Ebay :rolleyes:
SimonO said:
Mark Grant
like i say cant quite stretch to mark grants £108 for 2 as i need other cables as well
yes i see the 2m is 41.99, oh well, ebay is just cheap stuff at that distance, ive found some profigold i might try any other recommendations?
cheers lee
SimonO
lee_car said:
...like i say cant quite stretch to mark grants £108 for 2 as i need other cables as well...
Sorry, I missed that :suicide: ...
Joe Fernand
AVForums Sponsor
Hello lee-car
Two 10m VanDamme Red Series S-Video cables will cost you just over £45.00 (total) inc shipping.
These are good for 20m so no worries at 10m.
Best regards
Joe
PS BetterCables Silver Reference S-Video is better - though at approx £80.00 (each) for a 12m cable its above your indicated budget - see http://www.bettercables.com/12me3febecas.html
cheers joe pm sent
Scott_Mac
We use the Profigold one at work and it's pretty good... bought from TVcables.
