s-video cable question
Discussion in 'Cables & Switches' started by dangerouseddy, Jan 11, 2005.
  1. dangerouseddy
    dangerouseddy
    Dec 23, 2004
    36
    at the moment i have an svideo cable plugged into the back of my sky+ box, the lead goes out throught the window and is fastened to the wall. its connected to my dvd panasonic e85 writerin my bedroom, i have interferance on the picture. is it because it is mostly outside or too long at 15m?, should i buy a better made 10m cable (which should be long enuff) or go for another option?
  2. dangerouseddy
    dangerouseddy
    Dec 23, 2004
    36
    would the Bandridge PGV6609 10m svideo lead do the job?
  3. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
    I would imagine the problems you are having is a combination of both distance and the fact that it is outside.
    I can only suggest something like this: http://www.keene.co.uk/cgi-bin/bigcodesearch.pl?C5B
    possibly using some 'outdoor' cat5 if possible, I have installed Wireless access points for computer networking and have seen weatherproof cat5 cables advertised, although personally I covered them with conduit.
    I know this is expensive, but other than getting a better quality s-video cable and running it through conduit, I don't know how else you can cover such a distance. ;)
  4. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
    expensive.
  5. dangerouseddy
    dangerouseddy
    Dec 23, 2004
    36
    thanks, i'll have a think about what to do.
  6. dangerouseddy
    dangerouseddy
    Dec 23, 2004
    36
    so does anybody know where i can buy some flexible metal conduit?
