S Video Black and White.
Discussion in 'General TV Discussions Forum' started by r.vernon1, May 5, 2002.
  1. r.vernon1
    r.vernon1
    Apr 20, 2002
    2,355
    Nottingham
    +129
    Tried using svideo from my Samsung 709 to my Toshiba 40PW13B, and the picture is black and white. Tried changing the out of the dvd player to s video as the scart output. Still the same. It is black and white on the setup screen so I can't be anything to do with dvds. Also just using a standard s video cable. Any ideas?
    Rob
  2. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    What AV socket have you got the DVD player attached to? Usually AV1 will be for RGB/Composite so try AV2 or AV3. If this doesn't solve the problem, are you using a fully wired Scart Lead? Lastly, you may need to specify S-Video on one of the AV Inputs via the TV's AV setup menu.
  3. r.vernon1
    r.vernon1
    Apr 20, 2002
    2,355
    Nottingham
    +129
    The dvd player normally is on av2 attached by normal scart, however, I now have it on the svideo connector on my tele, via an svideo cable, it came with the dvd player so I assume its okay. It shows up on av3. But b & w?. Does that explain it better?
    Rob
  4. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    Try hitting the AV Input Mode button once more when on the B&W picture. AV3 shares a composite/S-Video connection. You should be looking for something like AV3 S or AVS as an on screen symbol.
  5. fuzzybee
    fuzzybee
    Apr 27, 2002
    1,498
    Chesterfield town of the crooked (Spire)
    +72
    Easy answer is go into your menu and select feature menu then AV connection go to ext3 input I bet you a pound to a penny this is set to AV just switch it to S-Video.
    Your picture should now be in colour
    Hope this helps:confused: :confused: ;)
  6. r.vernon1
    r.vernon1
    Apr 20, 2002
    2,355
    Nottingham
    +129
    cheers m8, i knew it would be something simple, but guessed I over looked the obvious!!!
    Thanks again
    Rob
