S-video better than Scart?
Discussion in 'Cables & Switches' started by image165, Sep 30, 2004.
  1. image165
    Sep 30, 2004
    145
    +3
    I have a DVD player and an LCD TV. When I connect the two via an s-video lead, the picture is solid and smooth. But when I connect the two via RGB Scart, the picture has these wavey interference patterns visible in dark areas of the picture.
    So, is S-video better than Scart? If it isn't, why is the picture I'm getting using a Scart cable inferior to the S-video?
  2. bobbypunk
    bobbypunk
    The scarts may be RGB but have you told the DVD to output RGB and the TV to accept it (This is often necescery). If not then the scart will be sending a composite signal which is much worse than s-video. The other possibility is the leads being different, If it's a decent s-video but a cheap scart it would explain the interferance!
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,107
    Rainham Essex
    +2,380
    In theory RGB should be better than S-Video as RGB uses 3 cables to carry the video signals with one colour on each. S-Video carries colour on a single cable.
    In practice the above is not always true as some equipment will handle S-Video better than RGB and therefore you will get a better picture from an S-Video connection.
    Mark.
  4. image165
    Sep 30, 2004
    145
    +3
    Yes, I've told the DVD player to output an RGB signal via the Scart, and I've told the LCD TV to accept it. I'm using a Vivanco gold plated Scart cable. Despite this, I still get noise in dark areas of the picture, and very faint wavy interference patterns.
    Using an S-video lead, on the other hand, provides a perfectly stable, noise-free picture.
    Do you think my equipment (Panasonic) works best with S-video, or do I need to invest in one of those £40+ RGB Scart cables?
  5. bobbypunk
    bobbypunk
    It sound like whatever interferance the cable is picking up is the cause. So you can either find out what the source of the interferance is and see if it can be stopped or buy a scart like a qed sqart or a ixos XHT601 from a dealer with a nice policy of return if you're not happy!
  6. malcmall
    malcmall
    Oct 7, 2004
    61
    How do you tell your dvd player to send rgb and the tv to receive it? i thought it was done automatically! :confused:
  7. Contact
    Contact
    Oct 17, 2004
    64
    The options normally in the DVD set up menu (accessable when the DVD's stopped), or a physical switch, normally on the back near the connections.
