S-Video and 5.1 from XBOX?
Discussion in 'Xbox Forums' started by NickBull, Aug 1, 2002.
  1. NickBull
    NickBull
    Can this be done? It looks like it's S-Video and normal sound or Scart and Digital toslink? Or have I missed something?
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    The Joytech £15 lead can do this I think.
  3. NickBull
    NickBull
    Thanks, I'll check it out.
    Nick
  4. shabbyroad
    shabbyroad
    Yes, S-Video and 5.1 out (optical) works. I have it hooked up to my Seleco320.
    After playing Halo and a bunch of other games on my projector and in 5.1 the TV just doesn't cut it anymore.
  5. museumsteve
    museumsteve
    Jan 28, 2001
    8,005
    4
    Nth Hampshire
    +1,109
    indeed mate..now if only more people had the opportunity to experience it..:)
  6. NeoBlade
    NeoBlade
    Hehe I will soon-ish... Halo in prog.scan and in 5.1. Should be good ^_^
  7. museumsteve
    museumsteve
    Jan 28, 2001
    8,005
    4
    Nth Hampshire
    +1,109
    happy for you mate..:)
  8. penfold
    penfold
    I was looking for one of these ages ago, as I would like to use the DVD for the TV's only RGB input. Is the S-video picture decent quality? I couldn't believe the difference between composite and RGB for the Xbox video cable. I know S-vid ought to be closer to the RGB than to the composite.
  9. dejongj
    dejongj
    Neoblade, how will you be doing Xbox progressive scan? Have you imported an US Xbox or is there another trick.....
    I am currently playing Halo on a 8ft wide screen in 4:3 with full 5.1. This is so spooky when all lights are out in the room and the sound is fully cranked up..... Progressive scan would even improve on this experience....
  10. NeoBlade
    NeoBlade
    dejongj,
    Messiah is the man to ask since he one one of the first on the forums to get his Xbox chipped and used the video select CD. Basically with this boot disk you can change the region of your Xbox from PAL to NTSC. Once changed into NTSC the Xbox can output in progressive scan (480p) which is sweet for any european owners who can benefit form progressive scan.
    I've heard that once you've used the boot disk the Xbox would remember the setting so you don't have to use it again.. I can't confirm this but there are people who have copied the video select CD to the hard drive and made it boot up with the Xbox straight away.
    Its certainly good news since the graphics will be even better.
  11. 2manyconsoles
    2manyconsoles
    Aug 21, 2002
    142
    16
    Chester
    The Advanced AV pack (only available through import) can do this also - cost me £30 from videogameimports.com
  12. NeoBlade
    NeoBlade
    Joytech offers the Component cable + Optical lead for £15 as stated by Nic Rhodes, so there isn't a need to import a Component cable anymore. You would though if you wanted one for the Gamecube...
    Anyway the European Xbox cannot output in progressive scan with a modification as stated on my previous post. No matter how hard you jam in that new Advanced AV pack, its not going to give you progressive scan out of the box ^_^
