S-Vid out from SKY box
Discussion in 'Sky Digital TV Forum' started by ralpher, Jan 9, 2005.
  1. ralpher
    ralpher
    Dec 21, 2004
    12
    Hi guys. Currently have a Panasonic SKY box which does not have s-vid out. Want s-vid out for connection to LCD screen which has no scart. Could go for the RGB to S-VID converter from JStechnology, but this would be £75.
    Thought about the alternative which is to upgrade the Panasonic SKY box and get something more powerful, but will still let me use my SKY card. I have SKY+ upstairs which has s-vid but don't want to move it and don't want a second SKY+ box. Started looking at other Sat receivers - DREAM etc, but know sweet fa about them.
    Does anyone have any suggestions? Appreciate your help!
  2. mray
    mray
    Feb 16, 2004
    2,728
    83
    London
    +217
    Grundig make/made a Sky Digibox that has s-video out on the back. I don't know the model number, but They have a few on Ebay.
  3. Flimber
    Flimber
    Sep 22, 2002
    13,360
    Yorkshire
    +4,477
    A SCART TO S-VIDEO CABLE DOES NOT CONVERT ANYTHING.
    Scart is a plug type not a signal format.
    Grundig GDS 210/2, 310/2, GDS-3000 all have s-video out as does Sky+.
    Caps intentional, sorry.
    Mike.
  4. ralpher
    ralpher
    Dec 21, 2004
    12
    Agree, cable does not convert, so the converter is essential. Thanks very much for the Grundig info - I knew someone on here would come up with a solution.
    Excellent, thanks
  5. mray
    mray
    Feb 16, 2004
    2,728
    83
    London
    +217
    Hi Sinbrad.
    Will a Skybox output s-vid via the scart socket? I was under the impression that it was rgb or composite only. Thanks in advance.
  6. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Most cheap so called scart-svideo cables leave the buyer with a black and white picture, they are for the most part intended for a STB which outputs s-video via the scart socket.
    You have to make sure you are getting a cable/convertor which actually does take RGB from the scart and converts it to s-video at the other end amd they are more expensive.
  7. mambojambo
    mambojambo
    Dec 23, 2004
    141
    +3
