s-vid direct to PJ question
Discussion in 'Projectors, Screens & Video Processors' started by JDC, Mar 19, 2002.
  1. JDC
    JDC
    I have an 'old' Rotel RSP 966 processor, the rotel 995 DVD and a Tosh MT proj. I feed the projector with an s-video cable from the DVD. There is a slight reduction in pic. quality when the video is routed through the processor, but I want to add a VCR for TV & some VHS duties. I can't change the cable routing whenever I change source (cable runs buried in plaster to the PJ) so, is my only option to feed both DVD & VCR through the processor to switch source? Any clever alternatives?
    Any advice welcomed, so long as it doesn't involve buying a new, better processor!!
    Cheers.
