s-vhs
Discussion in 'Digital TV & Video Players & Recorders' started by Ricky27, Feb 10, 2002.
Tags:
  1. Ricky27
    Ricky27
    Feb 8, 2002
    1,975
    Norwich
    +220
    hi,im going to buy a new video in a few weeks and would like to buy a s-vhs et model,possibly from panasonic,whats this format like and is it worth the extra money?
  2. Kevo
    Kevo
    Aug 23, 2001
    5,425
    Manchester
    +158
    YES, it's worth the extra money although I much prefer the JVC range. My last two Panny SVHS VCRs were CRAP. Cheaply built, unreliable and a dreadful SVHS picture. Maybe they've improved recently I don't know.
    I'm well impressed with the pic on my new model, JVC HRS-8850.
  3. Garrett
    Garrett
    Apr 21, 2001
    43,260
    2
    167
    The best thief you'll never see.
    +8,178
    You can get a Panny S-VHS around £200 I have seen them as low as £161, but the one with the jog shuttle are better for cutting ads out(i.e. stop when the ads come on then get it to the exact spot where they start press rec. then when they have finished press pause, you can hardly see the join), only thing is now the do not have this function on the remote.
    :cool: Ruby quartz shades.
  4. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    SVHS can be worth it, but it depends what you want to do with it. If you time shift and watch rentals then you might be better off looking elsewhere. SVHS are a premium product but need to be used to their advantage.
