S-VHS signal from SCART socket?
Discussion in 'AV Receivers & Amplifiers' started by Darren Blake, Jul 15, 2003.
  1. Darren Blake
    Darren Blake
    Apr 28, 2003
    625
    Norwich, UK.
    +15
    Hi all.
    Not really an aplifier question, but it is driven by my intention to connect all my video sources to my Denon 1803 using s-vhs.
    Both my Sony VCR and Grundig Sky box have SCART output only. I was planning to use a Maplin SCART to s-video adaptor to extract an s-vhs signal from both. However, I have just learned that not all SCART sockets are wired for s-video support.
    I have put a question in the General Hardware forum asking for advice on whether the Maplins products I have chosen will do the job, but in case they are pass-through only, what are the chances my VCR and Sky box will have s-vhs compatible SCART sockets?
    I only ask because I cannot physically get to my gear to check this until Thursday, and it is on my mind! Plus my Denon 1803 came in today and as it was a special order they won't take it back if I can't get it to talk to my equipment...
  2. dmach22
    dmach22
    Oct 15, 2002
    80
    N. Yorkshire
    +4
    Darren,
    Unless your vcr and digibox can output a s-video signal I'm afraid that this box will be of no use. Most vcr's only output a composite signal through the scart output, unless they are a svhs vcr.
  3. Darren Blake
    Darren Blake
    Apr 28, 2003
    625
    Norwich, UK.
    +15
    Thanks for the reply. This was pretty much what I was assuming would be the problem. Hopefully both SCARTs will be s-video wired, but I'm not going to bet any money on it.
    All may not be lost, though. Having already bought the box from Maplin, maybe I can use one of their composite to s-video converters to change the source to s-video?
    See this thread from "General Hardware"
    I'm having to go to all this trouble because I would rather switch all my video sources through s-video than have to run yet another 5m feed to the screen for composite.
    Regards,
  4. roversd1
    roversd1
    Chord Co. do nice Scart - S-Video cables for around £40. Carefull how you chose you scart leads because some come with very heavy connectors that tend to fall out...
    If your Grundig / TV does RGB, hook it up direct via scart to scart for the best picture.
    There are also many good respectable RGB to S-Video converters around from about £25
  5. Darren Blake
    Darren Blake
    Apr 28, 2003
    625
    Norwich, UK.
    +15
    Can you point me at a website or shop? The only ones I can find are in the £100 bracket.
  6. roversd1
    roversd1
  7. DaveP
    DaveP
    This is probably a silly question so just ignore it if you think so!
    Have you checked the back of your digibox? Most of the Grundigs have s-video out sockets next to the av outs.
    DaveP
  8. Darren Blake
    Darren Blake
    Apr 28, 2003
    625
    Norwich, UK.
    +15
    I am 99.99% sure that mine has not (but I shall kick myself if it does). I'll check again tonight.
    Depending on whether my 1803 can switch a composite sync signal to accompany RGB, I may change to RGB for my SKY and DVD interconnects.
