S-VHS on Philips 6006
Discussion in 'General TV Discussions Forum' started by damolong, Jan 6, 2003.
  1. damolong
    damolong
    May 15, 2002
    73
    I now have an Xbox and I have been experimenting with connections. Scart 1 (RGB) is too dark as I suspected (known problem with these TVs). Using the phono cable into the AV composite video slot results in a picture which isn't very sharp.
    The TV manual says that the 2nd Scart is S-VHS. However, when I connect the scart to this socket, the picture quality is no better than when using the AV phono slot. It also comes up on the TV as EXT2.
    When I select the AV options on the remote, I can select TV, EXT1, EXT2, S-VHS2, and AV.
    How do I get S-VHS to work? Do I have to select something on the X-Box? I have looked through the menus but can't find anything.
    Any help greatly appreciated.
  2. gingerone
    gingerone
    Dec 10, 2002
    2,567
    +388
    Connect to ext 2 and select svhs2 and that is s-video.
  3. damolong
    damolong
    May 15, 2002
    73
    I can't remember what came on the screen when I tried that but fairly sure it was a black and white blurry picture.
    Anyone know if I have to tell the xbox to transmit in s-vhs? Do you have to have a certain type of scart cable to be able to use s-vhs?
