S-VHS Connection on a Sony DAV-SC5
Discussion in 'Home Cinema Buying & Building' started by hossacd, Aug 4, 2004.
  1. hossacd
    hossacd
    Jun 28, 2004
    115
    +18
    I am thinking about buying the Sony to hook up to a Panasonic TX22LT3 for our bedroom and wall mount the screen and the speakers hiding the cables in the wall, however due to the size of the plug I can't run a scart cable to the screen so the next best option is to run a S-VHS cable however it is not clear from the Sony webpage if this model has as S-VHS out socket as I can't get a scart to S-VHS cable long enough (7-10m). I would be grateful if someone with this model could check this for me ?
  2. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    You could get the cable made,
    try -
    www.intoav.com
    Great cables at good prices.
    Cap :)
