s/pdif will phono do it ??
Discussion in 'Cables & Switches' started by gil2, Oct 29, 2005.
  1. gil2
    gil2
    on the back of my Pc guys i have a s/pdif yellow plug , that a phono cable fits , can i use a normal phono cable from there to my amp to carry digital , or do i need a special cable with phono connectors ??
  2. Peridot
    Peridot
    Aug 24, 2004
    2,995
    Newport, South Wales
    +293
    A 'normal' phono to phono cable will work fine :thumbsup:
  3. digital zombie
    digital zombie
    Feb 5, 2008
    77
    +5
  4. Member 34135
    Member 34135
  5. digital zombie
    digital zombie
    Feb 5, 2008
    77
    +5
    if you dont mind me asking what would the main advantages of that cable over the other as isn't the signal digital so it would either work or not??? or am i completly wrong :confused: may i add that the pc is not very far from amp eg 1.5 meters
  6. ben.bayliss
    ben.bayliss
    Feb 4, 2007
    1,198
    63
    +136
    If it works then it works, but if you're going to be buying a new cable for this purpose then it would be silly to not buy the 'correct' sort of cable.
    In your case you've already got a working solution, so there's no problem.
