Don't know much about optical/toslink cables.
I'm assuming I can connect the s/pdif output from my pc straight into the digital input of my dac?
If yes, then any advice on what type of connections I should use.
Does the s/pdif go straight into the digital optical (toslink?) input of the dac? Or into the digital co-axial rca input connectors?
I would need to get a cable approx. 7m long? Any recommendations? Not too bothered about paying silly money for anything high-end, just something reasonable to listen to internet radio
cheers
jag
cheers
jag
