S/PDIF outputs
Discussion in 'Desktop & Laptop Computers Forum' started by jpfrost, Apr 19, 2005.
  1. jpfrost
    jpfrost
    Jan 18, 2003
    93
    I am trying to put together a HTPC. My current PC has onboard 7.1 sound but as far as I can tell has no S/PDIF output (not really sure what to look for!) to connect to my AMP.
    Is there anyway to convert my 7.1 outputs to coax/optical input on my AMP?
    Or is my only option to buy a sound card with S/PDIF outputs?
    Thanks in advance
  2. Skunkpipe
    Skunkpipe
    depending on your sound chip there may be an option to turn one of the outputs (such as line/Front L-R out) to spdif - This will give you co-ax SPDIF, you'd just need a 3.5mm jack -> RCA cable.
    However there are issues with some onboard sound chips getting anything more than DD-2/Stereo out over SPDIF.
  3. sted
    sted
    Jan 20, 2004
    79
  4. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    I actually got a normal cd rom audio cable cut off one end and soldered on a normal coax socket then connected the other end to the spdif header which was on my motherboard. worked flawlessly with my pc. do a search for spdif pinouts on google different motherboards have different pinouts i think. Mike
