S/PDIF-out Interface
Discussion in 'Desktop & Laptop Computers Forum' started by Clamicpo1, Aug 14, 2004.
  1. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,847
    Alvaston/Derby
    +265
    Hi, I've got an Asus motherboard & would like the above, does anyone know where I can get one.
    Thanks in advance
    Charlie
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,180
    UK.
    +2,721
    ebuyer did a front plate that went into a 5.25drive for external output, but you can fit it inside and either run the lead to your amp via a hole/pci slot, or make a short lead from the phono to another phono on a PCI blanking plate.
    The only other way (as the corrct part doesn't seem readily available when I looked about a year ago) is to try ebay USA:
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=31492&item=6701351710&rd=1&ssPageName=WDVW
    Don't know if this will work:
    http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=43693
    HTH
    Gary.
  3. MikeC
    MikeC
    Mar 14, 2001
    225
    Northants,UK
    +10
  4. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,847
    Alvaston/Derby
    +265
    Hi, Thanks Gary, I've ordered one from your link.
    All the best
    Charlie
  5. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,180
    UK.
    +2,721
    If it works OK, let us know will you? It could be usefull for for others.
    Cheers.
    Gary.
  6. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    I managed to get hold of the order form (you can`t order without it and they email it in xlt form hence my other post) filled it in and sent it off just waiting to receive it now :) if anyone wants the form let me know and i`ll email it on
  7. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    3,849
    2
    LONDON
    +6,161
    Am I correct in guessing that this allows you to connect your amp to your sound card via an optical cable?
    Dino.
  8. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    Yeah you can do that, i just want to connect to my Inspire 5.1 via the optical cable which is same as an amp really ;)
  9. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    3,849
    2
    LONDON
    +6,161
    Grovvyyyy! :D
