S/PDIF Dies on my AV32R
Discussion in 'TAG McLaren Audio Owners' Forum' started by primeaniac, Apr 5, 2005.
  1. primeaniac
    primeaniac
    Welll after about 40min my digital output dies, not the toslink but all the S/PDIF outputs and the OSD didn't work either! But when it has been off for a while i works again. Feels to me like some heating problems for some electronic components!
    Has anyone any other ideas?
    Regards, Thomas
  2. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    I assume its not sat on top of something hot?
    Sounds like a phonecall to the helpdesk......
  3. primeaniac
    primeaniac
    Well it stands on my poweramplifier but it has been standing there for a couple of weeks and the problem just started yesterday!
    In many HIFI configurations the preamplifier stands on the poweramplifier!
    /Thomas
  4. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    Never put the AV on top of the power amplifier......The manual even says that....... Move the AV to a well cooled shelf with nothing hot underneath and see if the problem goes away... You may have damaged the unit though already.....
