RZ42PY10 DVI connection
Discussion in 'Plasma TVs' started by iJeff, Apr 9, 2005.
  1. iJeff
    iJeff
    I have an LG RZ42PY10 (HD Screen) and Denon 2910 DVD player, these I have connected with a DVI cable (Denon setup has DVI switched on), yet I get no signal on the Plasma?? I have a PC with DVI out and tested that with the Plasma and that was fine - could my problem be a faulty Denon or a compatibility/sync issue between DVD and Plasma?
    if it's a sync issue, are there DVI inline connectors that solve these issues? Do either equipment have an engineers menu to change DVI settings?
    Any other ideas?
    Thanks for your help.
  2. richiecas
    richiecas
    Dec 29, 2004
    87
    Do you have sky or sky+ connected tothis screen. I am thinking about getting one but would like to here people's experiences beforehand. Did you look at any other screens before purchasing and why did you pick this one?
