RZ42PX11 High Def
Discussion in 'Plasma TVs' started by Paulxxiii, Apr 17, 2005.
  1. Paulxxiii
    Paulxxiii
    Nov 20, 2004
    26
    Hey there folks, can someone help shine a light on this enquiry.
    Im looking to get the new xbox 360 when it is released oct/nov this year. they say all games are goint to be in high def possibly through hdmi / dvi its not confirmed yet, i have my dvd player running through prog scan component, so i dont really want to use this connection for the xbox, im hoping to use my dvi connection. so after all that. is it possible to get high def images from the xbox onto the plasma, or is the plasma not high def compatible, cause i thought if i had dvi then it must be. am i wrong??
    any help would be appreciated.
    cheers folks.
  2. zAndy1
    zAndy1
    Nov 26, 2002
    19,816
    2
    5
    163
    +6,964
    It should be fine, I suspect it will be possible to output 720p @ 60hz from the Xbox2 (even a UK one should hopefully cater for that refresh rate) which the LG should accept just fine. Obviously it will downscale it but it should still look very nice!
    Cheers,
    Andy.
  3. Paulxxiii
    Paulxxiii
    Nov 20, 2004
    26
    cheers matey, that has put my mind at rest a bit. much appreciated
