or for the same priceBrand new you are looking at Radeon RX 6500xt, Nvidia 3050 or older 2060 in that price bracket. Personally if it was me I would try & stump up a little bit more & go for the Radeon RX 6600.
PowerColor AMD Radeon RX 6600 Fighter 8GB Graphics Card
6500XT is a terrible value proposition and is easily beaten by a second hand option.Brand new you are looking at Radeon RX 6500xt, Nvidia 3050 or older 2060 in that price bracket. Personally if it was me I would try & stump up a little bit more & go for the Radeon RX 6600.
Cracking deal, if I was in the market I would go for that.or for the same price
Just make sure your PSU is up to it.Thanks everyone will look at the Rx 6700..
650w means little, it really depends on the brand and the rating of the PSU, if its a decent brand it will likely be a 650w but some of the cheaper brands just stick wattage labels on the psu, know it sounds a bit negative but I've repaired so many pcs with crappy PSUs that claim 1000w and are actually putting out a unstable 350w.Thanks I have got a 650w psu.
