rxv-2500 vrs vsx-2041i ?
Discussion in 'AV Receivers & Amplifiers' started by jumar, Jun 6, 2005.
  1. jumar
    Jun 3, 2005
    just when i thought i had narrowed it down to the denon 2805 and the yam 1500 i find some great prices for the vsx-2014i and the rxv-2500 which would be in budget!!!! ive phoned arround my local dealers 200 mile radius and can't get demos so i will have to take advice from you guys again on this one!the amp will need to drive kht 2005.2 and its mainly for t,v, movies,then music it also would have to complement a panasonic th42pv500cab i currently run it with a yam dspax620 which is doing a good job of it but like allways the grass is often greener on the other side but sometimes its just dark brown!!! hence advice req regards mark... :lease:
