Rx-v730
Discussion in 'AV Receivers & Amplifiers' started by ddp1960, Apr 25, 2002.
  1. ddp1960
    ddp1960
    I am pretty much settling in on getting the RX-V730 from Yamaha, any one have any experience with this unit before I spend the cash? I had considered the 620 but they are hard to find and the difference in price from 630 to 730 is not much.
    My next issue will be that the JBL speakers I have are a set of 6 so now I have to consider do I need/want to get another center speaker for the rear
    comments?
