Rx-v479 4k
Discussion in 'AV Receivers & Amplifiers' started by ellie666, Aug 13, 2018.
  1. ellie666
    ellie666
    Dec 5, 2002
    70
    Spooner Drive, Quahog
    So, i have a sony kd65xe9005, a panasonic ubd300 4k player and a Yamaha Rx-v479 amp.
    It is all connected thru amp with 1 connection from the blu ray and 1 from the tv (amongst others)
    4k plays fine when watching Netflix or prime on tv and if i put a regular blu ray in also no prob, however if i stick a 4k disc in it moans about 2.2 problems and downscales to 1080 :(
    So do i have any practical options or am i looking at dropping another £400?
    I have regular 5.1 and am not interested in atmos
  2. Mark.Yudkin
    Mark.Yudkin
    Sep 19, 2007
    10,068
    Zurich, CH
    +1,551
    The RX-V479 supports HDCP 2.2, as does your DMP-UB300 (and TV), so you should not need to drop £400 on any more electronics.
    Check the firmware levels on all devices. Also verify that you are using certified premium HDMI cables no longer than 3m.
  3. ellie666
    ellie666
    Dec 5, 2002
    70
    looks like I had plugged my 4k player into the wrong port on the Yammy, a legacy of my Blu Ray player being plugged there.
  4. Mark.Yudkin
    Mark.Yudkin
    Sep 19, 2007
    10,068
    Zurich, CH
    +1,551
    So the resolution saved you £400 and you can take your wife out for dinner. :)
  5. ellie666
    ellie666
    Dec 5, 2002
    70
    Yeah but don't tell her that
  6. Mark.Yudkin
    Mark.Yudkin
    Sep 19, 2007
    10,068
    Zurich, CH
    +1,551
    Of course not, it's going to be your surprise, isn't it?
