RX-V2600 connection advice
Discussion in 'AV Receivers & Amplifiers' started by pmatthews, Dec 30, 2006.
  1. pmatthews
    pmatthews
    May 13, 2005
    26
    3
    Dublin
    I am in the process of setting up my equipment in a new cabinet, the equipment consists of a Yamaha RX-V2600 receiver, Panasonic PT AE900 projector, Sky HD, Toshiba HD DVD player (US import), Sony DVD player (HDMI), XBox 360, 40" Sony LCD, Mordant Short Genies 5.1, Advent MCE PC, HDMI switcher (3:1) and Philips iPronto remote.
    I would be grateful for on any advice in regards to suggested connections to achieve the following: I would prefer to use HDMI for both sound and video where possible.
    All sources can be output to either the TV or Projector via HDMI.
    Sky HD connected including 5.1 surround.
    Toshiba HD DVD setup for 5.1 and multichannel PCM.
    DVD player setup for 5.1 and upscaling. SACD via Multi Channell.
    XBox 360 connected via component and for 5.1
    PC conneced via DVI and setup for 5.1.
    I would like to achieve the above with the least amount of cables as possible.
    Thanks for any tips advice etc.
    Paul
