RussJ
Discussion in 'Blu-ray & DVD Players & Recorders' started by RussJ, Jan 5, 2004.
  1. RussJ
    RussJ
    Feb 5, 2002
    257
    Norwich
    +11
    My new E60 is installed in a cupboard with glass doors but unfortunately the door frame obscures the IR "eye" which means I can't get line of sight with the doors closed. As a result the remote doesn't work unless I open the doors. My old JVC VCR had no problems despite being in a similar position and would happily function if the remote was just waved in the general direction of the recorder.
    Is the Panasonic remote particularly weak or the "eye" insensitive? (batteries are brand new).
    I guess the only option is to buy an extender...
  2. dude1971
    dude1971
    I have the same problem, I have to sit on the other end of the sofa to use the remote and it very annoying. I guess it's just weak :-(
  3. Dan Smiffy
    Dan Smiffy
    I have a Panny HS2 and it's the only box on my AV stand (positioned at a right-angle to my telly) that I have trouble operating from my sofa - 3m at 50degrees away. Everything else - inc. a Panny VCR as well as an Arcam dvd and Denon amp - can be controlled fine. T'is a bit annoying having to lean forward before I can tape anything ;)
    dan.
  4. Ged
    Ged
    Apr 29, 2002
    946
    +24
    There are remote extenders you can use, they pickup a signal using a small reciever, convert to RF pump it to another transmitter which you can position inside the cabinet.
    Try Keane Electronics, I think it is called "remote extender"
    Ged
