running time on panasonic thpw4b
Discussion in 'Plasma TVs' started by neil w, Jan 1, 2005.
  1. neil w
    neil w
    Jun 13, 2004
    487
    +18
    hi
    could someone please tell me if its possible to find this out via menus on the screen
    yhanks
    neil
  2. prattr
    prattr
    Apr 4, 2004
    11
    3
    With the Plasma on, hold the volume - button on the Plasma in while pressing the button under the power button on the remote (the status button) 3 times very fast
    When a menu box comes up, high light the SD mode, then press the sellect button (the square button on the remote). This tells you how many times you have powerd on and off the panell on the left (WT) and on the right (PT) an hour meter. Put the plasma into standby to exit.
  3. neil w
    neil w
    Jun 13, 2004
    487
    +18
    thanks
    neil
  4. wicket
    wicket
    Nov 23, 2004
    493
    Middlesbrough
    +10
    Does anyone know if this works on the TH42PE30?
  5. Twan1
    Twan1
    Dec 19, 2004
    1,132
    38
    Essex
    +22
    does any one know roughly how many hours you can get out of a plasma??
  6. neil w
    neil w
    Jun 13, 2004
    487
    +18
    well mine has
    been turned on/off 5400
    has run for 5956 hrs
    neil
  7. prattr
    prattr
    Apr 4, 2004
    11
    3
    I have had my TH42PW4B for just over 3 years now and it has clocked up 11030 hrs with no problems. The picture still looks as good as the day I brought it :smashin: . I have now brought a 435XDE so the Panasonic has been moved up to my spare room till I decide what I am going to do with it.
    Ricky
