Running speakers in??
Discussion in 'Home Cinema Speakers' started by mikeq, Feb 24, 2003.
  1. mikeq
    mikeq
    Hi all,
    Just bought Gallo Nucleus Micros. When people talk about running speakers in what exactly needs to be done, i.e. should they be played at a certain volume? if so what should it be? Is there anything else I should be doing?
    Regards
    Mike
  2. juboy
    juboy
    You raise a good point about running in where speakers like the Gallos are concerned... usually 'running in' is the process of making the drive units move in and out for a long enough period of time that they 'settle' into their correct/optimum position for all future use. I don't know whether the same thing applies in the quite the same way to speakers with a design like Gallo's.
    That said, I'm sure they'll still benefit to some degree. The easiest way to burn in speakers is to set a full-frequency range music CD on repeat play for a couple of days when you go out to work. It doesn't need to be excessively loud, just about the same volume as you might sensibly listen to the music at normally. Don't use acoustic or lightweight discs... if you have any Prodigy albums or similar, they're a good bet.
  3. mikeq
    mikeq
    Thanks Juboy
    It'll have to be something in the Heavy Rock genre I'm afraid:) I'm sure I have something that will do it.
    Mike
  4. juboy
    juboy
    That'll do the job. Try and make sure it has some nice sparkly treble and some deep bass... anything with a range of frequencies and dynamics would be fine.
  5. Lesmond
    Lesmond
    Jan 29, 2003
    +3
    From the Monitor Audio website:
  6. aka
    aka
    What about subwoofer?
    Is "runnin in" also applies for subwoofer??
    rgds,a-k
  7. jim.rae
    jim.rae
    There is a huge amount of bull**** about all of this...
    All you need to do is run the speakers at a reasonable level for a weekend and they will settle down fine.
    Don't go to any more bother than that and as you listen to them, they will settle down in no time.
  8. Lesmond
    Lesmond
    Jan 29, 2003
    +3
    Are you quoting more bull**** here, or just overruling an established manufacturers recommendations with your own? :eek:
  9. juboy
    juboy
    I think what jim.rae was trying to say is that there's an awful lot of myth and hoopla tacked on to the generally accepted knowledge that most speakers will begin to achieve their true potential after 50 to 100+ hours of usage (obviously this depends on the speaker and materials used in their construction).
    I tend to agree with him. Unless you rarely listen to your music collection, most 'burn-in' can be done by simply listening as you would normally do, to a variety of different music styles, for a couple of weeks.
    The very last thing I would do is spend £20 on one of those 'burn-in' discs...
  10. Dazed
    Dazed
    Mike
    I too have the Gallo NM's and the good news is that they sound like completely different speakers after the run in period, I would say I ran them for about 30-50 hours. I really noticed the difference after thrashing them with the the Rammstein CD Mutter. I was aware of a run-in period but that didn't stop me being ever so slightly disappointed with my NM's when I first hooked them up. Now they sound oh-so sweet - an incredible difference.
    The only downside in all this is that I've only "run-in" my two fronts as I'm still awaiting delivery of a Pioneer 2011 - which fingers crossed should arrive soon
  11. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    yep I would go as far as to say that the Gallos are transformed by a fairly lengthy run-in period in that they sounded like completely different speakers after three weeks of use.
    Dazed you're not running your front two through a regular stereo amp are you?!
  12. Dazed
    Dazed
    Yep, but connected through the sub
    Stereo Amp>MPS150 Sub>Gallo NM's
  13. James45
    James45
    Sep 21, 2002
    2,844
    59
    whew!!:smashin: Had me worried there.:D
