Running Speakers In..............uh??
Discussion in 'Home Cinema Speakers' started by Wilfred Whale, Mar 10, 2003.
  1. Wilfred Whale
    Wilfred Whale
    How do you do this then?
    I assume that it means that you dont turn the volume up too loud to start with, but whats too loud?
    Any advice? Does it differ for mains, centre's, rears, subs etc?
  2. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    if you think its too loud it probably is... unless of course you're my girlfriend in which case you're talking rubbish woman! Do you have sonar or something... I can hardly hear it!:rolleyes: :devil:
  3. mjn
    mjn
    May 24, 2001
    22,067
    Herts, England
    +9,805
    place the speakers so they face each other, and then put one speaker out of phase with the other.
    And leave them for a while, depends on who makes your speakers, as different manufacturers specify different running in times.
  4. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    Is that the latest way to do it then :confused:
    I suppose now your going to tell me only the top boys do it that way
  5. mjn
    mjn
    May 24, 2001
    22,067
    Herts, England
    +9,805
    you can do it any way you wish, my suggestion is only 1 way.
  6. ditton15
    ditton15
    Oct 20, 2002
    536
    16
    edinburgh
    The technical term for running in speakers by having them face one another is a dialogue. I'm not familiar with the technique of putting the speakers out of phase. Does this extend the dialogue, or is that what you folks in Dublin call the craic?
    ditton ;)
    I bought my Celestion Ditton 15s in 1976, so they are probably run-out by now. However, I did recently buy some Gallo Nucleus Balls, and they improved over time. This apparently is standard.
  7. Gambit
    Gambit
    When you do it mjn's way (which is good), by putting one speaker out of phase, when one drive unit is pushing out, the othe rone is pulling in (because they're out of phase) so the additional pressure, I assume, caused by the drive unit pushing on the one pulling means they are run in faster. You don't need to play your speakers overly loud to run them in, just play something with a decent frequency range, and leave it on repeat while you go out or whatever.
  8. Wilfred Whale
    Wilfred Whale
    Will someone please explain how i put my speakers out of phase!
    I took my speakers and put them together as suggested but i couln't find a switch to change the 'phase' of them, even after looking in the instruction manual. Is is something i have to do on the amp?
  9. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    Put the positive (red) connection to the negative (black) connection and vis-versa on one speaker only. This speaker is then out of phase relative to the other one. If you then put them facing each other, very closely, the out of phase sound waves partially cancel each other out. This allows you to turn up the volume more than you probably would otherwise. If you're serious, then throw a duvet over them as well, put the CD on repeat and leave them like that for 48hrs.
