Hi all,
This is my first post so please go easy on me
I have a question on routing speaker wire through the walls on an already finished room. Basically what I am wanting to do is mount the rears on the "back" wall of the room and route the associated wiring down between the "back" wall frame, through the sub floor into the crawl space and the back up into the "front" wall.
Ive done some investigating and both are interior walls, neither of which have any installation so that makes it a bit easier to route the speaker wires. I went down into the crawl space to see if I could figure out where the walls were placed and all I could see was the sub floor (big surprise).
So my question is this:
Do I have to remove a section of the drywall big enough to facilitate drilling down through the subfloor or is there an easier way? I would prefer to come from below and drill up if possible. Also, should I expect to encounter horizontal cross studs within the framing of the wall as I route the speaker wire?
Any help would be appreciated.
Thanks!
Thanks!
