Running power and signal cables- A Different Question
Discussion in 'Cables & Switches' started by aramil2003, Jun 21, 2005.
  1. aramil2003
    aramil2003
    I've heard that if you run a power cable accross a signal cable at a 90 degree angle, so the two cables form a '+', interferance isn't possible.
    How true is this?
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    It depends what sort of interference you're talking about but there is certainly some truth in the statement. :)
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I would put it like this: two cables running in parallel ('=') are more likely to interfere with each other than cables running at an angle (with 90 degree being the max/best).
    As so often there might also be cases in practice where you won't have any problems running cables in parallel, say if the signal cable has a very good shielding.
  4. aramil2003
    aramil2003
    So should I run them like this or route a new track around the signal cable (instead of accross).
  5. demostenes
    demostenes
    Hi all, :hiya:
    There's always interference :thumbsdow even if u run a power cable near a low voltage cable (even from telecom transmitters like cell phones and radio signals) therefore most people try to place them as far from each other as possible. Of course when crossing its wise to cross them at 90º. Why?... :lesson: ..
    The electromagnetic waves travel in a helicoidal way on AIR, try to imagine an airplane propeller. The cable is for guidance only. As most power cables are unshielded (for electrical waves) and with poor insulation there's always a leakage which results is spray magnetic and electrical fields which in turn injected parasitical voltages or currents in the nearby cables.
    What can we do:
    1- Increase the distance
    2- Use + for crossings
    3- If u have to run both cables parallel :nono: , use successive twisted loops so that the magnetic (only) induced voltage is reduced
    Sorry the short lesson :suicide: .
    Beekeeper as a looong explanation in: http://www.avforums.com/forums/showthread.php?t=106899
