Running parallel or at right angles to power cables (damage limitation)
Discussion in 'Cables & Switches' started by matblack, May 12, 2005.
  1. matblack
    matblack
    Jul 30, 2003
    406
    +10
    The cellar roof space is like a rats nest of power cables and I need to run S-video and component cables and speaker cables right across the them.
    I will have to cross at right angles and/ or run parallel to some but I can limit it. The question is what is going to be the one I should avoid most :lease:
    MB
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    In my experience S-Vid is the only one that's had interference problems but they were certainly noticeable. I would place any other video cables next in the list and put speaker cable as the last of your priorities. It will be very obvious if you have noise induced in your speaker cables as it will be within the audible spectrum so if you have problems then you can go back and play around again. :)
  3. matblack
    matblack
    Jul 30, 2003
    406
    +10
    I'll run all the new cables pretty much together and take the clearest route but its the intersections with the power cables that worry me though. I can go across them at right angles OR run parellel, which would be best?
    Going back aand playing around isn't an option :(, the plasterboard wil go on AFTER I run the cable and I won't have much of a chance to test :(
    MB
  4. matblack
    matblack
    Jul 30, 2003
    406
    +10
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Definitely right angles. Don't forget that you may also be able to vertically space the cables by putting something between them. :)
  6. matblack
    matblack
    Jul 30, 2003
    406
    +10
    I think I can get a vertical gap of at least an inch between the power and the other cables for each 90 degree intersection :)
    MB
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    also dont cross video cables if you can help it run them seperately well spaced and dont for get you can move the power cables too...........(obviously make sure they are off and you follow good safety procedures.
