Running on the spot
Discussion in 'General Chat' started by monkeyleader, Feb 12, 2009.
  1. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    Hey - just wondering when the weather is bad if running on the spot is just a waste of time or you still get something out of it ?
    cheers,
    Nige
  2. Iccz
    Iccz
    Apr 29, 2008
    24,060
    Keystone City
    +6,750
    I find running on the spot pointless, it's effectively just knee ups, if you want to do knee ups you must as well run outdoors lifting your knees up higher, good for building calfs/thighs - not bad for you though.
    When you run you're pushing yourself, which is working more muscles and working them harder and is more cardio vascular. I believe you work your abs and other more with moving too.
    Upward propulsion vs forward propulsion.
    Forward is both upwards and forwards :thumbsup:
  3. ufitsy
    ufitsy
    Aug 18, 2004
    3,280
    103
    Midlands
    +353
    Find some stairs - always a good workout.
  4. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,393
    +850
    I'm guessing the OP is hoping he can get away with calling playing on wii fit exercise :D
  5. The Dude
    The Dude
    May 21, 2004
    6,772
    Beverley, East Yorkshire
    +3,241
    If you get a sweat on, or you get out of breath, or even if you just get a bit tired, then you're definitely getting something out of it. :)
  6. Synax_Injector
    Synax_Injector
    Aug 24, 2008
    3,059
    +666
    In that case, I get exercise going to the toilet :D
  7. The Dude
    The Dude
    May 21, 2004
    6,772
    +3,241
    Abs, Thighs, Glutes and sphincter. :D
    - maybe forearms too...... depends on your diet.
  8. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    -10lbs with nothing but wii fit ... yer it must all be in my head ;)
  9. Iccz
    Iccz
    Apr 29, 2008
    24,060
    Keystone City
    +6,750
    Any kind of burn is a burn, but it's mostly down to diet and exercise, burning more calories than you consume etc... you could sit in your chair doing leg lifts and still burn...
  10. The Dude
    The Dude
    May 21, 2004
    6,772
    +3,241
    :thumbsup:
    - Speaking as a proper gym monkey, and also a Wii Fit owner...
    Anyone who can't afford / be bothered to go to the gym, should definitely buy Wii fit instead..
    I do an hour's Wii fit on my nights off from the gym.
    30 mins yoga, 10 mins Hula hoop, 20 mins other fun stuff.... :smashin:
  11. Iccz
    Iccz
    Apr 29, 2008
    24,060
    Keystone City
    +6,750
    Above post is true, also anyone wanting to get started out into fitness Wii fit is an excellent way to do it, helps with keeping it fun, easy and in the privacy of your own home, perfect for anyone starting out, not really much use to anyone who's already into a fitness schedule though to be honest.
  12. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    I'm not sure that it is any less effective than when the weather is good :D
