Running old DOS games on an xp machine
Discussion in 'PC Gaming & Rigs' started by the_sanguine, Apr 14, 2005.
  1. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
    My 9yo son has been given a pentium III machine running xp and wants to play games. I have some old DOS games (The ones where you ran a boot disk and the game ran in DOS). Can he play them or not?
  2. jenic
    jenic
    Dec 10, 2004
    2,909
    83
    +180
    I run space invader which was a win 98 dos game on my xp machine in command prompt and it works fine.
  3. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
    Command prompt? Gizza clue!
  4. jenic
    jenic
    Dec 10, 2004
    2,909
    83
    +180
    Just double click the game file and it should load automatically in command prompt, thats how i do it. I am not that technical with the advanced ways of dos so if it does not work i will ask a friend.
    If you know dos then you can prob use command prompt.
    Its in start>all programs>accessories>command prompt
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Some will work, some probably won't as Win XP basically has to emulate a DOS environment. :)
  6. Pbryanw
    Pbryanw
    Nov 15, 2004
    1,524
    N.E. Lincs
    +101
    There's a very good dos emulator for Windows XP called DOSbox. It can run some old games but not all. Get it here:
    http://dosbox.sourceforge.net/news.php?show_news=1
    There's also a link to which games will and won't work on it on this page as well. I used to use it to run sensible soccer (the PC version) but I've forgotten how to configure it, so you'll have to have a tinker with it. There's a good forum if you get stuck.
    If you want to run old adventure games on your XP machine (like the Lucasart ones) there's Scummvm:
    http://www.scummvm.org/
    Easier to use then DOSbox but only runs adventure games.
  7. quik
    quik
    Sometimes you may need to run XP in compatability mode. Right click on the exe file, go to properties and select compatability mode. Then select Windows 95 or 98. THat helps. Also running the app in seperate memory space, again in properties.
  8. Gizmo 76
    Gizmo 76
    Aug 17, 2003
    2,236
    116
    The Apps are Calling :-S
    +495
    But what bloody superb adventure games they are . . . . . . . . . . :D
  9. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
    Thanks Guys, I'll try some of these ideas when I get a bit of time
