Running Modded Xbox in Hi Def on Xbox Live
Discussion in 'Xbox Forums' started by [email protected], Mar 9, 2005.
  1. ashleyhyatt@mac
    [email protected]
    Can someone tell me...
    If I was to get my Xbox modded and activate the Hi Def Output... would the Hi Def still work when the mod chip was turned off to play on Xbox Live.
    The only real reason I would mod my Xbox is to play Hi Def games such as Halo 2... I only play Xbox Live games as single player games do not interest me anymore.
    I hope someone can answer this!
    Thanks.
  2. danvitale
    danvitale
    Nov 18, 2004
    2,340
    63
    By The Sea
    +114
    Ok. Summary. You can run a "exploit" (otherwise known as a "soft mod") that allows you to change the output of your XBox to output NTSC. This will enable the Hi Def options as long as you had a Hi Def Xbox pack connected.
    You can do this by running a suitable "soft mod" game (I used an original copy of Splinter Cell) and by using a game that contains the Enigmah video switch. This can be downloaded from the Net and using something like an Action Replay, the save can be put on a memory card. There are plenty of threads here that show you how to do this.
    It doesnt affect your Xbox live as it only switches the video output.
  3. ashleyhyatt@mac
    [email protected]
    Thats sounds perfect !
    I have the official component lead for the Xbox and I have an Action Replay too !
    I've been searching the net and forums and whenever some talks about the Enigmah Video Switch they are refering to it being used with a modded Xbox ?
    I will purchase Splinter Cell today, could you please tell me how to make this work as I have no idea what to do !
    Thanks.
  4. danvitale
    danvitale
    Nov 18, 2004
    2,340
    63
    By The Sea
    +114
    Have a read of the big thread about Xbox and Hi Def, specifically the last ten pages.
    you need to ensure that you purchase a ORIGINAL copy of Splinter Cell, as the "Classics" version has the exploit hole fixed. Ebay or the second hand bin of your local gaming store would be the best places. I bought mine second hand for £5.
  5. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    This link tells you. I am going to get myself an action replay and try this.
    Matt
  6. o THE CHAD o
    o THE CHAD o
    Nov 22, 2003
    1,480
    London
    +83
    me too.
  7. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    You dont need to have an action reply you can use the cheaper Max Drive.
  8. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    So where do ya get this Max drive thingy and is it as well supported as the Action Replay. Can u get it in the high street or is an online jobbie
    MAtt
  9. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    Max drive is made by Datel who makes Action reply so yes its well supported.
    Play have it for £14.99 - 16meg version you can also get 32meg and 64 meg versions from codejunkies.com web site. All the saves you need are on the codejunkies web site.
    As for shops selling it........Argos, Game, Gamestation, HMV, Virgin,Dixons, Currys, Comet etc etc.
    Max Drive is the fast, easy and secure way to transfer files between your Xbox and any PC.
    • Low on memory card space? Max Drive can store the data from TWO standard Xbox Memory Cards - the perfect backup solution. You can even use Max Drive to move game saves from your Xbox memory card onto any PC's hard drive. Just imagine all that extra storage space at your fingertips!
    • Download the latest game saves using your PC's internet connection then use Max Drive to transfer them to your Xbox ® Memory Card.
    The fast & easy way to transfer game saves and more between your Xbox and any PC.
    Max Drive is a memory card revolution!
    • Max Drive™ has the capacity of two standard XBOX memory cards.
    • Stores even large game saves that don't fit on any regular memory cards
    • Use Max Drive™ to move game saves from your XBOX onto your PC's hard drive. Just imagine that flexibility at your fingertips!
    • Download the latest game saves, rosters, high scores and more using your PC's internet connection then use Max Drive to transfer them straight to your XBOX
    • Max Drive™ is compatible with USB 1.1 and USB 2.0 ports on a PC, and simply plugs into an Xbox controller port using the supplied X-Adapter.
  10. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    Ok could only get the Xploder memory save jobbie.
    Reading instructions on what to do and im lost already :eek: It says delete any Splinter Cell saves from your HDD. Done then it says put game in StartGame and select Linux. WTF is LINUX and where is it I dont have anything that says Linux within the Splinter Cell game menu??
    Matt
  11. msrx7mh3
    msrx7mh3
    Jul 2, 2003
    1,091
    38
    London
    +13
    Ok, I'm not sure if you ahve read the steps on the link posted above clearly, but it does state that you have to transfer the "hacked" savegame exploit to the memory card.
    You then deleting any existing gamesaves on the xbox (as you appear to have done). Then copy across the hacked exploit from the memory device to the xbox.
    THEN:
    "for Splinter Cell load up the game, choose "Start Game", select the profile "LINUX" Choose "Check Points" (not "Levels"). It causes the screen to turn white and freeze)
    If you’ve done everything correctly you should see the EvolutionX dashboard and you have successfully modded your Xbox without a modchip!"
  12. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    I have downloaded the Zipped SC file but I am not sure what I have to and how I send this zipped file to Xploder . In manual it says drag n drop but it is saying not a valid save file??
  13. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
  14. o THE CHAD o
    o THE CHAD o
    Nov 22, 2003
    1,480
    London
    +83
    shame you dont live near me manic mate,you could borrow my action replay and i could borrow your splinter cell!
  15. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    DOHHHHHHH
    Its because the Xploder does not support the Action R files I have downloaded
    Double DOHHHHHHHHHHHHHHH
    Matt
    And triple Dohhh cos LFC I think said DONT USE XPLODER
    DOHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
    Matt
  16. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
  17. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    Woo Hoo :clap: LFC posted what to do and it worked I am now running Hi Def :thumbsup:
    Matt :hiya:
