Running in time of a AV32R DP
Discussion in 'TAG McLaren Audio Owners' Forum' started by Martin_M, Sep 13, 2004.
  1. Martin_M
    Martin_M
    Jun 13, 2004
    20
    the Netherlands
    According the manual the running in time will be a few hours. I think that's a bit short :rolleyes:
    My AV32R was recently upgraded to the DP version. I noticed that the mainboard was totaly replaced (with a 2001 version). Perhaps because mine was one from the very beginning.
    It's now 4 day's later and I still miss liveliness and airiness between the instruments i.c.w. the AV32R SP (played 12 hours a day and one whole night).
    There are also improvements of course (better bass and hights, cleaner, better pin-pointing) but the stage is still little small and it sounds a little 'plastic-like'.
    Has anyone the same experience and how long took it to get better? I can't belief that the DP is worse then the SP at this point.
    Martin
  2. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Dunno, our stuff always worked well straight out of the box once warmed up. They would have left the thing on for a good while when they tested out the upgrade (possibly overnight or 48 hours even) so I doubt it needed that much running in.......As no-one else has said this about the DP (and it certainly was better than our SP) I wonder if all your settings are right? bass re-direction, crossover point, TMREQ etc.......
  3. Martin_M
    Martin_M
    Jun 13, 2004
    20
    the Netherlands
    TMREQ is off and I listen in direct mode without a sub.
    Other settings (speakerdistance, soundlevel etc.) are all doublechecked.
    A friend of mine has de SP version. After a few weeks we will have a shootout between the two units.
    Martin
  4. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Beats me, the difference was pretty obvious even straight out of the box with our DP. I know Steve did some work on the whole bass/time alignment thing in a recent version of the software, but I'm not sure the work spilled over to the SP? Maybe it is this difference that might take a bit of gettig used to. The centre soundstage in direct mode on our DP and AV192R is spot on.
    I'll be curious as to what you think of them side by side when you do your shootout.
    Maybe just a case of re-adjusting your ears to suit the new processing, I think you will be happy with the result.
  5. Jack van Dijk
    Jack van Dijk
    Apr 21, 2004
    34
    11
    Wageningen, The Netherlands
    Ah, a shoot out! Count me in!
    Jack
  6. Martin_M
    Martin_M
    Jun 13, 2004
    20
    the Netherlands
    Jack, you're most welcome :thumbsup: Bring your DVD32FLR ;)
  7. @Home
    @Home
    Jan 28, 2004
    1,647
    48
    +83
    Make sure you have a box of tissues handy for your friend.
    When he hears the AV32 DP he will weep with astonishment.
    Baring in mind that the AV32 SP kicks butt :zonked: .
  8. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Are we talking about a get together? I'm game.
  9. Smurfin
    Smurfin
    Aug 13, 2002
    21,442
    +4,386
    Look forward to reading about the results of this:)
  10. Martin_M
    Martin_M
    Jun 13, 2004
    20
    the Netherlands
    After little improvements in time, suddenly on the ninth day everything we were missing was back....and even better :clap: .
    @Graham; Well, we're positioned in the Netherlands. If you don't mind a little travel..........
    I will keep everyone posted here about the results.
    There are two sets we will testing in:
    Besides the AV32R's:
    1. Martin: TEAC P2, Krell KSA300s, Wilson Audio Watt/Puppy, Transparent cables
    2. Blue-Eyes: TAG McLaren CDR20T, Mark Levinson No.331, JBL Ti-K 10, MIT cables
    And Jack brings his DVD32FLR.
    Martin
  11. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    I go to Brugge a fair bit and Holland is only down the road..... Where about in Holland?
    What happened on the 9th day to improve matters suddenly?
  12. blue-eyes
    blue-eyes
    Jul 16, 2004
    16
    Lelystad, the Netherlands
    Aaah! Shoot-out! Count me in :thumbsup: :clap: :smashin:
  13. blue-eyes
    blue-eyes
    Jul 16, 2004
    16
    In the middle of Holland, the newly build part. We create a dike, throw some water away and build some houses. One of them is Martin_M's :p
  14. Martin_M
    Martin_M
    Jun 13, 2004
    20
    the Netherlands
    On the 9th day the soundstage became more open. There was more air and lively sound.
    I gave it a thought. My Transparent speakercable could also be the guilty part in this. Transparent cables must always 'settle in' when there is a change in the set. However 9 day's is quite a time....
    Martin
  15. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    :rotfl: :rotfl: :rotfl: :rotfl: I can see Glenn Strauss reaching for the shotgun as I type......
  16. Martin_M
    Martin_M
    Jun 13, 2004
    20
    the Netherlands
    Graham, from Brugge to my place is 303 km and 3,5 hour by car :eek:
  17. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    About 2 hours in my thing then......
  18. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    ... and 20 fuel stops! :D
  19. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    It will do 189 miles on a tank with "sprited" driving....... I once entered a 50 minute endurance race and ran out of fuel on the last lap but was going fast enough to finish (tank was full at the start, 13.1 gallons......you do the maths.....). I've just seen a 5.2L version of my engine, I really really want it........
  20. Joelc
    Joelc
    May 16, 2004
    414
    +5
    GrahamMG:
    What do you drive?
    Cheers,
    Joel
  21. Teejoo
    Teejoo
    Apr 24, 2004
    221
    The Netherlands
    +3
    Indeed, I hear already stories about French cheese coming up....... :D
    But, anyway. Martin, If you do this shoot-out, make sure TMREQ is properly setup!
  22. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Amongst other things, an MGBGTV8 (not exactly standard as many already know)......
